I have searched thru the forums I was unable to locate any topic that solved my issue. Some seemed close but no go. So if I have missed the correct post please direct me to it.
The drive in question is the SATA ASUS DRW-24B1ST a-49 manufactured Nov 2010. I have tried a second DVD drive also with same results.
SPECS as copied from system information
OS Name Microsoft Windows 8 Enterprise Evaluation
Version 6.2.9200 Build 9200
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name COOLER-MASTER
System Manufacturer System manufacturer
System Model System Product Name
System Type X86-based PC
System SKU Unsupported
Processor AMD Athlon(tm) 64 X2 Dual Core Processor 6000+, 3014 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date Phoenix Technologies, LTD ASUS M2N32-SLI DELUXE ACPI BIOS Revision 2101, 8/6/2008
SMBIOS Version 2.4
BIOS Mode Legacy
BaseBoard Manufacturer ASUSTeK Computer INC.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.2.9200.16442"
User Name Cooler-Master\COOLER-MASTER\Toby
Time Zone Eastern Standard Time
Installed Physical Memory (RAM) 3.00 GB
Total Physical Memory 3.00 GB
Available Physical Memory 2.00 GB
Total Virtual Memory 3.50 GB
Available Virtual Memory 2.42 GB
Page File Space 512 MB
Page File C:\pagefile.sys
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions No
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
Neither drive will read or write. They both show up in device manager but when a disk is put in it will click and light will blink then will eject the disk saying please insert a disk into drive. I have tried the upper and lower filter in the registry. Uninstalled the drive then reinstall. Set boot order to dvd drive first in system settings. Disabled all boot options in system settings except DVD drive. I have changed out hard drives with no OS installed and still will not boot from either DVD drive. My windows 8 trial version expires in 11 days. If I am unable to resolve this by thin I am dead in the water. I have been able to install other software as long as it is located on a hard drive.
I wish to thank anybody who happens to read this post even if you can offer no help. At least you looked. Thank you.
SMBIOS Version 2.4
BIOS Mode Legacy
