DVD Optical Drive sata cable help
YiHao Xie
7
hey i have a slim dvd drive that has two slots. one for motherboard and another for power supply, but i dont have the connector for it and i dont know what it is called. i searched up sata power adaptors but they are all dont fit. the slot looks almost identical to the one that connects to the motherboard but it looks like an L and shorter while the sata data cable looks like L mirrored. the model is GTB0N from LG. link to where i bought it: http://www.amazon.com/dp/B00ODDFROE/ref=pe_385040_128020140_TE_3p_dp_1
if you have a link for a adapter for what i described, please send it
can you explain to me what both cables are called?
