Dvd playback looks horrible, help?
Koyanti
17
As stated my dvd playback looks like there is a fog over the screen or the lens was dirty when they were filming the movie and the dvds play crystal clear when using dvd player and tv. Also streaming netflix looks much better than dvd as well. Is there any way to fix this? Will switching from vga cord to hdmi cord help? its painful to watch dvds on my computer and that is so not right.
My system is:
CPU: i5-2500k
GPU: ZOTAC GeForce GTX 560 Ti ZT-50304-10M Video Card - 1GB, GDDR5
MOBO: ASUS P8Z68-V PRO/GEN3
MEMORY: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
MONITOR: ASUS VE278Q 27" Widescreen Full HD LED Monitor - 1080p, 1920x1080, 16:9, 10000000:1 Dynamic, 2ms, Integrated Speakers, DVI, VGA, HDMI
OPTICAL: LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM
Why are you still using VGA lol. And VGA to HDMI youll notice a difference in how crisp and clear it looks. But I'm not certain it would eliminate the problem your having. Try that and see if it makes a difference.
Yes switching to hdmi should help. Vga is analog, while hdmi is digital. You've got a really nice monitor and vid card. There's no reason a dvd should look like crap besides the type of cable connection or a driver/codec issue.
I cant be certain if thats the problem until you get your HDMI cables. If it still persists then it could be something wrong with the DVD drive.
