Question DVD player will not read "D" Drive.
Apr 20, 2019
4
I am running Windows 10 on a HP Computer. The DVD Drive will only show the "F" Drive and not the "D"Drive. After inserting a proper CD or DVD the door opens and says "Insert CD/DVD".
Any advice would be appreciated. Thank you.
USAFRet
The displayed drive letter for the optical drive may be D, or it may be something else completely. F, in your case.
What DVD are you putting in there?
Have you tried it with a production DVD, not something you burned?
Apr 20, 2019
4
Yes Sir, I have tried new CD's and DVD's. But it is not recognizing any of the. This morning I replaced the DVD Player completely...but the results were the same. So I'm sure it's not a DVD failure.
AllanGH
Commendable
Mar 10, 2019
1,519
275
1,640
45
If your hard drive and CD/DVD drive use the same interface, try switching the cables between the two and testing it out again.
Of course, if your system refuses to boot, after swapping cables, you've found the problem....but it's rarely THAT easy.
