G
Guest
Guest
I have a 700mhz athlon with 384mb ram and a asus 6800deluxe graphics card.
I just bought a toshiba 1502 dvd player, but while playing it is very jerky, the cpu usage is 100% most of the time. Should a 700mhz athlon with the geforce card not be good enough for playing dvd's or do I need to by a decoder card?
I also have a problem with it crashing as well, windows 2000 has crashed several times using asus dvd and win dvd, same problem, screen freezes and the sound locks too. The first time it happened, it trashed windows 2000, after a complete re install the same happened, but luckily the machine will reboot now. I am using all the windows updates and the latest detonator and via drivers. Does anyone have any idea what is wrong?
thanks
al
thanks
al
