C CryptoLocker Reputable Jun 4, 2015 79 0 4,630 May 31, 2016 #1 What Write speed should i put to make it work properly on Ps2 Slim using IMGburn Sorry 4 my bad eng
Solution Phillip Corcoran Jun 1, 2016 Select the slowest write speed that is available as that will minimise the risk of write-errors & coasters (bad discs). If you still have problems, try a different brand of blank discs.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,105 912 120,140 Jun 1, 2016 Solution #2 Select the slowest write speed that is available as that will minimise the risk of write-errors & coasters (bad discs). If you still have problems, try a different brand of blank discs. Upvote 0 Downvote Solution
