DVD-RW does not appear in XP to write CDs
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware,alt.os.windows-xp (More info?)
I have a Sony DVD-RW that correctly appears in the hardware
configuration as a Sony DVD-RW DRU-500A. The problem is that I cannot
get WinXP to see the drive as also capable of burning CDs. For
example, I would like to right click on a file and have the option to
"Write these files to CD".
Will XP not allow you to burn CDs with your DVD burner?
Thanks,
Tom
peter
3,226
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi,
No, XP does not support DVD burning rom , you need third party software,
e.g. Nero, Roxio, Plextor and many other softwares.
Peter
> Thanks,
> Tom
G
Guest
Guest
Peter wrote:
> Hi,
> Peter
What? Did you read the question? the OP wants to burn CDs. I have a Sony
DRU510A and it burns CDs without a problem using XP's burning engine.
The OP should check the drive properties and see if burning has been
enabled. My Computer, right-click on the drive, select Properties and
open the Recording tab. "Enable CD recording on this drive" should be
checked.
G
Guest
Guest
Phil McCracken <Phil@McCracken.com> wrote in message news:<10osk4rrsc1t1ae@corp.supernews.com>...
> Peter wrote:
> > Hi,
> > Peter
> checked.
That was it! I can't believe I didn't see that already. Thanks!
--Tom
