Archived from groups: alt.video.avid_editors,alt.video.dvd.software,comp.publish.cdrom.software,rec.video.desktop,alt.video.dvd (More info?)
I have Vegas Video 4 and I have the plugin that will allow it to deal
with VOB files. Great because I'm buying workout DVDs now instead of
VHS ones so that I can create my own customized workouts.
I just tried ripping two of my new DVDs and then taking the VOB files
into V V 4 only to have no audio. I was able to do this a few days
ago so don't know why no audio waveform today in V V 4.
I have the AC3 option checked under the Compression tab in DVD Shrink
but nothing. Just to make sure, I also tried DVD Shrink re-author
with the subfolders for Video_TS and Audio_TS when backing up, and in
the Audio_TS the folder is empty. I don't know if having that folder
empty has any bearing on this problem at all, but thought I'd mention.
The reason why DVD Shrink is so important for me is that I can
re-author and pick parts out that I need visually. From these main
workout DVDs, I'm creating specialized "targetting" ones, as I refer
to them. I used to do this with my bought VHS workouts using 2 VCRs.
Needless to say, so much easier with DVDs and a computre but it's no
good if I can't get the audio because I do need it half the time for
this. Alternative is to rip entire DVD to mpg when I need the audio
from the workout itself and am not replacing it with my own music mix,
and then cut it up but, man, I really don't want to go that route.
Any ideas on what is wrong? I'm using DVD Shrink v3.2.0.15. I've
just spent (wasted?) two hours on searches on the net looking for "no
audio" problems related to DVD Shrink and nothing that has come up
deals with the problem I'm having.
Thanks.
Thanks.
