DVD with 2 audio streams
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
I'd like to make a bilingual DVD (with 2 audio streams). I'd like to know
if I have to encode the audio using the left channel for one language and
the right channel for the other (i.e. both languages in the same sound
file), or if I'd need to create two separate audio (ex.: wav) files and then
use my DVD-creation program to create 2 separate sound streams? Also, does
a multi-language track use more space than a normal (single-language) one on
the DVD? (I suppose it does if you use 2 separate files) Thanks!!
DVD-Lab Pro supports multiple audio tracks.
And yes, having 2 audio streams should take up about twice the space of
1 stream.
-WD
"Will Dormann" <wdormann@yahoo.com.invalid> wrote in message
news:V2HDc.166246$DG4.138865@fe2.columbus.rr.com...
know
and
then
does
one on
> 1 stream.
> -WD
So this means that the two tracks wouldn't be encoded on separate channels
in a single file, that's it? (There would be one 2-channel stereo file for
each stream)
Will Dormann wrote:
>> know
>> and then
>> does
>> one on
> 1 stream.
Not necessarily. If you placed one stream with uncompressed PCM audio,
and one with Dolby Digital 2.0 (.ac3), the DD will be considerably
smaller in size than a uncompressed format. If both were DD (.ac3) they
would be about the same size though.
-Richard
> each stream)
Yes, you will start out with two stereo sound files.
Your DVD authoring software will multiplex both audio streams into a
single VOB, though.
-WD
news:KvLDc.167312$DG4.134334@fe2.columbus.rr.com...
channels
for
> > each stream)
> single VOB, though.
> -WD
So will the result be a bigger vob file than if there was only 1 audio
stream?
Will Dormann <wdormann@yahoo.com.invalid> wrote in
news:V2HDc.166246$DG4.138865@fe2.columbus.rr.com:
>> know if I have to encode the audio using the left channel for one
>> language and the right channel for the other (i.e. both languages in
>> the same sound file), or if I'd need to create two separate audio
>> (ex.: wav) files and then use my DVD-creation program to create 2
>> separate sound streams? Also, does a multi-language track use more
>> space than a normal (single-language) one on the DVD? (I suppose it
> of 1 stream.
Yes, I wholeheartedly recommend DVD Lab Pro. I made a dual audio stream
DVD with no problems at all. Oscar (the programmer) is doing a great
job with the product.
Tim.
"Those who give up essential liberties for temporary safety deserve
neither liberty nor safety." - Benjamin Franklin
>>single VOB, though.
> stream?
Obviously. Say for example you've got 2 AC3 streams. That's going to
take up twice the space of 1 AC3 stream, assuming the bitrate used is
the same. You don't get something for nothing.
-WD
news:Cx0Ec.65$m91.14@fe1.columbus.rr.com...
> >>single VOB, though.
> > stream?
> -WD
OK, so...last question: that means the result will be 2 separate stereo (2
channel) audio files encoded inside the vob file, NOT one audio file with
each language on a separate channel, right?
Yes, I've already answered this.
-WD
news:lQ4Ec.170701$DG4.117046@fe2.columbus.rr.com...
(2
with
> -WD
And if I encode the audio at half the bitrate of the initial file (ex.: 192
kbps instead of 384), will the result be a file that would be the same size
as the original, but with 2 audio streams?
Yep, it should be about the same size.
Two 192kbit streams take up the same space as one 384kbit stream.
(aside from the overhead used by the stream itself, which should be trivial)
-WD
