Ive always used a HDMI on my monitors until I bought a ps4 recently which can only be connected to e monitor vie HDMI and my monitor only has 1 HDMI port so I now use a DVI cable to establish a connection between my PC and monitor .
Well , many times when I lock my PC and I come back after a few minutes when the screen has gone dark and try to resume it , I just black screen and nothing . If I connect a HDMI to my GPU to the monitor , the screen goes back to normal , as well as if i connect a HDMI to my motherboard , the scree goes back to functioning as well. If I unscrew and unplug the cable from my PC and plug it back in , it sometimes fixes it or sometimes when I unplug it from my monitor , that fixes it.
So , this can eaither be a faulty DVI cable , faulty DVI ports on either my PC or monitor and a compatibility issue with my GPUs drivers , which one do you specialists think is most likely to be .
