I purchased a Solarism 17 inch LCD which has a dvi-d as well as an analog connection.My graphics card (PNY GF3 TI 500)has a DVI-I and an analog connection.My problem is that when i try to use the dvi connection there is no signal.The vga connection works fine.I've tried hooking up a separate monitor(VGA) then connecting the lcd to the dvi,restarting.In device settings in windows the digital flat panel setting is grayed out.Tried nview,no luck.PNY was no help.Solarism tried to help.I'm running windows 98 SE.Sorry so long.HELP!!!!!!!!!!!!!
