I got a brand new DVI D cable to DVI D so I could connect my monitor (dvi d) to the other dvi d port in my Gigabyte 980 G1 card, however theres no signal.
Originally I have always used the VGA Cable that came with the monitor and used a DVI I adapter to connect it to the videocard, and there hasnt been a single issue (outside some weird lines due to the conversion from vga to dvi on the screen when gaming).
So there are some possible problems
I could try changing the cable, but is there something wrong that I am doing here? Should I get a DVI D to DP port (I dont think the 980 has a hdmi port only some ports that look like it, but are DP)? Or VGA to DP?
Update Checked the card again and it does have an HDMI port.
The videocard dvi d port is faulty.
The Monitor dvi d port is faulty.
The cable is faulty.
