Relevant bits of my setup - Windows 7 PC, 2x Radeon R290s. 2 Monitors, primary is a Shimian running 1440p through DVI, secondary is an LG running 1080p through HDMI. Have had it setup for a while with no issues.
I had to move my computer yesterday, once I set it all up again I was getting an error with my Catalyst drivers. The HDMI monitor was working fine but the other monitor was not detected at all. I reinstalled the latest Catalyst drivers.
After a restart the Shimian is detected, it turns on (backlight) but does not display anything. It became the primary monitor again so I had to use the alt+spacebar trick to switch the setup to mirrored rather than extended. The HDMI monitor is still working fine.
I've tried messing with the plugs etc to no avail. I have noticed that the Shimian has a poor design at the back which makes the DVI cable have to bend a bit but all the pins seem fine.
Within device manager both displays are showing up as 'generic pnp'. I'm not sure if that's correct?
Have done so much googling but haven't gotten anywhere, please help!
