E Elias_10 Commendable Jun 3, 2016 4 0 1,510 Jun 3, 2016 #1 I have 2 monitors with dvi-d and my pc have 1 dvi-i dual link (my graphics card is a nvidia geforce 960 2gb), and i want to get dual monitor setup so I wonder if this is possible and if so what do I need to get?
Solution TechyInAZ Jun 3, 2016 You'll need either an HDMI to dvi adapter/cable or a DP to DVI adapter/cable. I suggest Displayport since it works better than HDMI.
TechyInAZ Titan Jun 23, 2014 18,256 427 81,340 Jun 3, 2016 Solution #2 You'll need either an HDMI to dvi adapter/cable or a DP to DVI adapter/cable. I suggest Displayport since it works better than HDMI. Upvote 0 Downvote Solution
E Elias_10 Commendable Jun 3, 2016 4 0 1,510 Jun 3, 2016 #3 so something like these would work together?: http://cdon.se/accessoarer/adapter-dp-hane-till-dvi-hona-svart-p37575000 x2 http://cdon.se/hemelektronik/champion-2m-dvi-d-dvi-d-dual-link-p744886 x2 Upvote 0 Downvote
TechyInAZ Titan Jun 23, 2014 18,256 427 81,340 Jun 3, 2016 #4 That DP to DVI won't work. Reason being is because it has it's own graphics processing unit built into that big box looking thing. Look for DP to DVI cables. That should do it. Upvote 0 Downvote
E Elias_10 Commendable Jun 3, 2016 4 0 1,510 Jun 3, 2016 #5 what about this one?: https://www.amazon.co.uk/Displayport-Connecting-Graphics-Projectors-Displays/dp/B00B2HOVAA/ref=sr_1_5?ie=UTF8&qid=1464980021&sr=8-5&keywords=dp+to+dvi Upvote 0 Downvote
E Elias_10 Commendable Jun 3, 2016 4 0 1,510 Jun 3, 2016 #7 Okey, thank you very much! Upvote 0 Downvote
