[SOLVED] DVI-I cable to to DVI-D port
Actually my Wacom is already has installed dvi-i cable and I want to plug it to DVI-D port.
What are available inputs on your Citniq Wacom monitor.
Simplest solution would be getting DVI-D cable (if monitor has DVI-D input) or
HDMI cable (if monitor has HDMI input) or
you can use existing cable with DVI-I to DVI-D adapter.
https://www.cablesnmore.com/dvi-adapter-dvi-i-female-to-dvi-d-male
Hi, and thanks in advance
I have a DVI-I cable on my Citniq Wacom monitor
https://ibb.co/V99gz9j
The cable wont fit on my new NVIDIA RTX 2060 as it has DVI- D port.
https://ibb.co/p44pMQ6
How could I get it working, please?
Kind regards
what are those covered up ports? HDMI or DisplayPort?
It is possible to get a HDMI or DisplayPort to DVI adapter. Those adapters convert HDMI or DisplayPort to a DVI port and possibly an AUX for speakers.
Do you wanna use DVI to VGA? This won´t work with newer cards. Y
There are two options:
1st (recommended) Use an HDMI or DVI-D or DP cable. If your monitor doesn´t provide these ports, get a new monitor
2nd get a DVI to VGA converter
View: https://www.youtube.com/watch?v=7mSG0YYptNM
Thanks for your reply.
My graphics card does not have a vga port, it has a DVI-D port / Hdmi
Thanks for the kind reply. Yes those are HDMI and Display port. What do you recommend to use ? I've tried Dvi to Hdmi adaptor but it gives me a tinted image (red)
have a look at the connector on the other side of the cable which is connected to the Cintiq, maybe it´s connected the false way and you just have to use the other side´s cable connector for your card to fit in
The other side is attached to the bone of my Cintiq which I can't detach
Thanks for your reply. This seems what I'm going to try first.
It will cost much if I order from cablsnmore. Im from Saudi Arabia.
Do you think this cable will work either?
https://www.aliexpress.com/item/32769073235.html
