[SOLVED] DVI no signal, main monitor
Feb 18, 2019
11
Hey. My pc turns on and runs fine, but my my pc wont connect to my monitor. When i turn it on my monitor says DVI no signal and then turns off. I have tired with different cables like the VGA cable and i have tried with another monitor, but still does not work. Someone Plz help.
Specs:
Widows 10 pro
Asus Strix Geforce GTX 1050TI,
Motherboard: Asus Prime h310-Plus
I5 CORE 6500
16 GIG ram
Asus vs247 Monitor
Those pins, in the CPU socket, are extremely fragile. On the rare occasion it may be possible to bend the pins back into place and the motherboard will function properly again. In a lot of cases the pin damage is severe enough that the motherboard will need to be replaced.
Are you using the graphics output ports on the graphics card or the motherboard?
Is the motherboard's UEFI setup set to use the discrete graphics card as the primary/initial video device?
Have you also tried testing using the Intel HD Graphics 530 integrated graphics on the CPU with the video output ports on the motherboard?
Reactions: METROPLEX
So the cable i used before was a DVI cable, but i have tried with DVI connected to the graphics card, and i tried with a HDMI cable connected to the motherboard. so i have tried output ports on the graphics card and the motherboard. I don't know much about the UEFI setup, can you explain?
