DVI or VGA cable?
JesusFTW
41
I'm building a new PC and I am going to use my old monitor and VGA cable using a VGA F DVI M adapter as the R9 270X only has DVI and HDMI connections but I've read online that cheap VGA cables can damage quality so would I be better of buying a DVI cable and a DVI F VGA M adapter? This is only for a month or two until I buy a new monitor.
So I should buy a DVI F VGA M adapter to plug in to monitor and connect that to my GPU with a DVI cable. Would just a cheap £5 DVI cable work fine?
But, when the DVI cable carries analog signals (Like here) it is roughly the same. DVI as an digital interface is much better.
