DVI output problem (Radeon HD 6450)
Pavlova
Hi all,
Sorry if this was already asked about any other card, couldn't find any.
I bought a new AMD computer with the Radeon HD 6450.
When I got home, I noticed there is a flickering line on the screen when I use DVI (VGA had no such problem).
When I complain to the store, I was told that the VGA is "the primary output" for the card, and I can only use the DVI for a secondary screen.
Is there such a thing?
Did anyone experienced such a thing?
Thanks!
Try updating the drivers to the Current drivers from AMD. www.amd.com I doubt that it will change anything but you never know.
Have you tried using a different DVI cable? Try hooking the monitor up to another computer using the DVI cable to eliminate the monitor and cable as the cause.
Thanks, JKatwyopc.
I just downloaded the driver, and apparently mine is up to date.
I used this monitor with my old computer with the same DVI cable, and it was working perfectly.
The only other monitor I have has VGA only, but when I tried it, it had no such problem.
