Archived from groups: alt.comp.periphs.videocards.nvidia (
More info?)
Ive emailed Sanyo so maybe ill ask them if it will work ona TV. My
last email just asked if they could get one and cost and where from
Wait i did ask for some more detailed info. So that might have the
info i want if they even answer.
Thanks.
On Fri, 10 Jun 2005 20:44:25 GMT, "Sharanga Dayananda"
<sharanga@gmail.com> wrote:
>I dunno there doesn't seem to be anything called DVI-C. So mebbe that DVI to
>component adapter will work.
>Hopefully it won't fry anything.
>"PhxGrunge" <noname@qwest.net> wrote in message
>news:8kkqe.33$0L4.1509@news.uswest.net...
>> "Sharanga Dayananda" <sharanga@gmail.com> wrote in message
>> news
😱3jqe.6506$K5.2017@newsfe4-win.ntli.net...
>>> The component adapter you listed might not actually be suitable for PCs.
>>> If you check out:
http://store.salestores.com/sapodvitococ.html ( This is the exact same
>>> model you linked to earlier. )
>>> OR
http://store.salestores.com/sanyo20.html
>>> You can clearly see that 'tis a projector accessory.
>>> The info on the first link seems to indicate DVI-C ( I'm guessing here )
>>> Graphics cards do DVI-I which includes DVI-D. So this DVI to component
>>> adapter ( I'm guessing again, unless someone else knows better ) will
>>> PROLY only work with a projector. As I said 'tis a guess.
>>> The do have VGA to Component adapters all over the place. However even
>>> though the plug is a VGA adapter 'tis in fact carrying a different kind
>>> of signal over the connector and is used primarily for projectors. I know
>>> this for a fact, from my long months of searching for a HDTV adapter for
>>> the GF 6.
http://store.salestores.com/sapovgatococ.html is an example of a VGA to
>>> component adapter which will definitely not work on a PC graphics card's
>>> VGA output. Admittedly 'tis not a DVI to component adapter, but it is a
>>> "Jill haoulder" <43434.com.au> wrote in message
>>> news:ge9ja1195jhslr8j4nn59vcsj0d3ubbrtd@4ax.com...
>>>> Iam SO CONFUSED
>>>> Heres a link to the Sanyo DVi to componate adaptor.
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=331637&is=REG
>>>> I was just wodering what would be my BEST bet to get true HD on my TV.
>>>> Which one.
>>>> My TV is fully 720p and 1080i. I could buy both and try them out but i
>>>> would like not to do that and use the best right up.
>>>> Do i realy need a true DVI or HDMI to get realy good HD movies via my
>>>> PC ?
>>>> Thanks.
>> Confused? No wonder.
>> Component is analog. DVI-D is strictly digital. Don't know what DVI-C
>> is.
>> DVI-I has 4 extra analog pins which are usually used for DVI-I to VGA
>> adapters.
>> Unknown if those 4 pins on DVI-I can be used for component output.
>> Usually, you use a VGA to component adapter with computer video cards.
