B BloodlineIrish Reputable Jan 29, 2016 2 0 4,510 Sep 5, 2017 #1 I just bought an adapter so i can use a second monitor, but it seems to not fit fully onto the port even if it is compatible. Any Ideas?
Solution A A aquielisunari Sep 5, 2017 BloodlineIrish : I just bought an adapter so i can use a second monitor, but it seems to not fit fully onto the port even if it is compatible. Any Ideas? There is DVI D, DVI I and DVI A. Which is your cable and which is the video connection?
A aquielisunari Judicious Mar 31, 2011 6,499 14 33,015 Sep 5, 2017 Solution #2 BloodlineIrish : I just bought an adapter so i can use a second monitor, but it seems to not fit fully onto the port even if it is compatible. Any Ideas? There is DVI D, DVI I and DVI A. Which is your cable and which is the video connection? Upvote 0 Downvote Solution
ex_bubblehead Titan Moderator Aug 24, 2012 17,810 2,279 89,240 Sep 5, 2017 #3 Are you plugging into a DVI-I or DVI-D port? It makes all the difference in the world. https://www.google.com/search?q=DVI+port&source=lnms&tbm=isch&sa=X&ved=0ahUKEwje5Ia-jY_WAhXmh1QKHehhCyUQ_AUICigB&biw=1920&bih=979#imgrc=4zcPKJAX_CqBIM: DVI-I = 4 additional pins carrying the analog VGA signal. DVI-D = Digital ONLY. No pins for analog. A DVI-I adapter will NOT fit a DVI-D port. Upvote 0 Downvote
B BloodlineIrish Reputable Jan 29, 2016 2 0 4,510 Sep 5, 2017 #4 aquielisunari : BloodlineIrish : I just bought an adapter so i can use a second monitor, but it seems to not fit fully onto the port even if it is compatible. Any Ideas? There is DVI D, DVI I and DVI A. Which is your cable and which is the video connection? I bought dvi I instead of D. Thanks for the awareness upgrade kind person. Upvote 0 Downvote
A aquielisunari Judicious Mar 31, 2011 6,499 14 33,015 Sep 5, 2017 #5 BloodlineIrish : aquielisunari : BloodlineIrish : I just bought an adapter so i can use a second monitor, but it seems to not fit fully onto the port even if it is compatible. Any Ideas? There is DVI D, DVI I and DVI A. Which is your cable and which is the video connection? I bought dvi I instead of D. Thanks for the awareness upgrade kind person. You're welcome 😀 Upvote 0 Downvote
