Bought this DVI to VGA adapter from Canada Computers, it was causing the display to show up as a Non Plug and Play monitor in Windows and was not showing the correct resolution options (the adapter seemingly isn't passing off EDID information to the GPU like it should). In addition it was causing the display to flash white bars across the screen during boot.
I did an exchange and still have the exact same problems. There is an option to override EDID settings in Catalyst Control Centre but I haven't had great success with it, when I tried setting it to native res (1600*900) on my brother's display it stretched the picture off screen and left a black bar at the top. Overriding EDID worked fine on my 1920*1080 monitor but still had the white flashes during boot.
I have another DVI to VGA adapter which is working perfectly fine (Showing monitor name under Windows as well as proper resolution) here are pictures of the pinout of the problematic adapter (top) as well as the functional one (bottom)
Did I just happen to get a defective adapter twice or is it defective by design?
It seems like most DVI to VGA adapters on google images have the extra pins that my problematic adapter has.
