SKREFI Reputable Dec 11, 2015 18 0 4,510 Dec 11, 2015 #1 My monitor have only VGA and I now I bought the GPU: AMD R9 380 that have only DVI so I need a convertor! How can I choose one, I dont know anything about that, I sow same are Male, same are Famale... WHAT THAT meen ? 🙁
Solution alexoiu Dec 12, 2015 Then I suggest waiting for it. If adapter included in the package, then you can use a VGA cable.
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Dec 11, 2015 #2 Usually, the card comes with an adapter DVI to VGA. Have you received the card? Upvote 0 Downvote
SKREFI Reputable Dec 11, 2015 18 0 4,510 Dec 12, 2015 #3 alexoiu : Usually, the card comes with an adapter DVI to VGA. Have you received the card? I bought it but I dont have the card (GPU) atm, it takes same days to arrive Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Dec 12, 2015 Solution #4 Then I suggest waiting for it. If adapter included in the package, then you can use a VGA cable. Upvote 0 Downvote Solution
