N Nad 10 Commendable Jan 31, 2017 1 0 1,510 Jan 31, 2017 #1 I have GTX 1050 and it's not work with the dvi to vga monitor...help please
Solution Dark Lord of Tech Jan 31, 2017 You need this type. https://www.newegg.com/Product/Product.aspx?Item=N82E16812400402 StarTech DVI2VGAE DVI-D to VGA Active Converter Cable Is your active like this one ^
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,736 1,824 159,590 Jan 31, 2017 Solution #2 You need this type. https://www.newegg.com/Product/Product.aspx?Item=N82E16812400402 StarTech DVI2VGAE DVI-D to VGA Active Converter Cable Is your active like this one ^ Upvote 0 Downvote Solution
J junkeymonkey Polypheme BANNED Nov 11, 2013 17,389 4 66,960 Jan 31, 2017 #3 a active converter but like here theres that chance it may not work as you fully expect http://www.tomshardware.com/forum/id-3319384/hdmi-vga-converter-problem.html this stuff today is all about you support them cause its not supporting you anymore maybe best to look at specs and all before you leap ??? you needed a card that still offered native analog with at least dvi-''I'' port Upvote 0 Downvote
Snipergod87 Splendid May 26, 2009 5,584 2 29,965 Jan 31, 2017 #4 As said before you will need an active converter, the GTX 10xx series no longer support analog (VGA) out. Upvote 0 Downvote
