DVI/VGA Help
GamerT
Hey there
I bought a 7600 GT and it only has 2 dvi connections and my monitor hasa VGA cable.. This was no problem before because i could just connect the monitor to the pc but with the card in it doesn't give an image. Now my question is: can i just fix this problem with a VGA to DVI cable?
thx already
~GamerT
Yes!
Either DVI to VGA cable or adapter will work. I have both: a 1-inch plastic extension which converts DVI to VGA, and a 6-foot DVI to VGA cable that I can plug into my monitor. Choose whatever you find on the cheap! I think i got the cable because it was cheaper than the adapter at the time I was buying it.
