DVI vs Display Port vs HDMI picture and color difference.
exxDUDExx
67
Is there any?
I have 2 VG248QE running from 1 hd 7970 ghz.
One is connected with DV and other through HDMI.
DVI one is running at 144hz and HDMI at 60hz.
DVI has fainter colors and gives of a bluish color.
Both are setup exactly the same.
Am I missing some options somewhere that i did not restore to factory?
Also, all the changes are made in Catalyst not windows.
Plan on changing to Display port instead of HDMI. Will it give me 144hz and adjust the color?
Since no matter what you did the problem stayed with the first monitor, that would say the problem is internal to the monitor. According to the manual there is an "All Reset" option in the System Setup menu. Page 3-6 has a trouble shooting option for "Screen image has color defects"...
If this doesn't fix it, there is probably an internal hardware problem.
Will try to find the handbook.
But What I am seeing is it feels like i has a cool setting set somewhere. Also, it is a monitor I bought a year ago.
Another thing may be affecting is Catalyst settings. But I seem to have set everything to original and loaded the ICC profile through windows.
Yep but the more I tinker the worst it gets. I can not get it to look the same temp at all. One has bluish tint and fainter colors.
