I bought a DVI-D to VGA converter for the purpose of a dual monitor setup. I have one hdmi port at the back of my GPU, and one at my motherboard. I have one of my monitors plugged HDMI-HDMI inside my GPU and it works fine. When I plug in the second one it says that there's no signal. I test the converter on my main monitor on the old VGA cable used for my old computer on my old monitor which used to work. No effect. I tested it on the new VGA cable that came with my new screen-still nothing. I tried plugging in the converter to my motherboard - no effect. I tried doing that with the HDMI cable, no signal. I figured it has to do something with the integrated graphics card in my motherboard, which I enabled from the BIOS settings. My computer started tripping from there and didnt have the HDMI cable work from the motherboard nor GPU, saying no signal once bios was exited. None of the cables seemed to work after I exited from BIOS
until I turned off IGD. Then its like nothing changed. I do not know if there's a problem with the converter itself or a port or something else. I would love to get some assistance on this as I went through alot of hardware for a simple dual monitor setup.
I would like to note that I customely built my PC with a Geforce GTX 1060 6GB armor oc graphics card and that it has three displayports, one hdmi and one dvi-d in particular port.
My motherboard is an MSI Z170 Pro Carbon with one visible HDMI port and one DVI and nothing else port. Both of the DVI ports look the same and like this: http://prntscr.com/dhi9bh
Thank you in advance.
