Question Dye for Corsair XL5 Clear coolant?
stuffsneak
21
Hi,
I had used the custom cooling kit from corsair which contained XL5 Clear Coolant.
I want to add a shade of blue to it. Is there any dye compatible with this coolant?
I was thinking to use EK Cryofuel Dye Pack. Link below:
https://mdcomputers.in/ekwb-ek-cryofuel-dye-pack.html
I asked on their page if it is compatible but they did not recommend it.
Is there any other dye which I can use? (And hopefully get in India)
Thanks!
My Rig:
More pictures and info here:
Ralston18
This:
"I asked on their page if it is compatible but they did not recommend it. "
Who is "their" / "they" ? Corsair?
Check Corsair's website regarding the use of coolant dyes in the XL5 Clear Coolant and the coolant kit in general.
I would be very wary of adding any chemicals to the coolant - difficult to really know what those chemicals contain and what they might eventually do to tubes, pumps, etc..
Remember the cooler/coolant is to cool. Not necessarily be a pretty shade of blue. Or any other color for that matter.
Never let form get in the way of function.
Just my thoughts on the matter.
