dying light low GPU usage.
Salman Soomro
159
i have
c2q q9300 @3ghz
hd 5850 @915 mhz
asus p5q motherboard
the GPU usage doesnt go above 65% and this gets me really low FPS inthe game usually between 25 to 30 fps... the CPU is not bottlenecking as it's at 65 to 75 % at all cores in OSD msi Afterburner. is there a custom fix for it or just a plain game problem or the rig being too old.
the games version is 1.5 (i think)
if we can assume that CPU is the bottle neck than is there a way to get the game to use 100% or atleast >90% of the CPU. i am using cpu control to get all the cores to work.. otherwise the game only uses CPU2 100% and the other cores 20 to 40 %
waow.. i just desperately tried all of the settings and a combination of nil view distance and full field of view reduced the stuttering by a big margin now i only get occasional stutters(those hang the screen for almost 5 to 10 seconds) but these occur rarely and other than those game runs at 30 above 50fps and the GPU is still at 60 to 80%
