Dying Light PC Fps Issue
Iestinio77
13
Hi Guys, i am hoping you can help me solve an fps issue i am experiencing on the game Dying Light for the PC. When i play the game, no matter what graphics settings i change, the Fps is at 60, but has little freezes every few seconds or so. I have read that Dying light performance issues are linked to amd products, but i haven't found a solution. I have capable hardware to play on full settings but the fps freezes are very annoying. Looking forward for answers, thanks 😀.
GPU - MSI R9 270X OC Edition
CPU - AMD Phenom II X4 Black Edition 3.4GHz
RAM - 8GB
hi:
MINIMUM:
OS: Windows® 7 64-bit / Windows® 8 64-bit / Windows® 8.1 64-bit
Processor: Intel® Core™ i5-2500 @3.3 GHz / AMD FX-8320 @3.5 GHz
Memory: 4 GB RAM DDR3
Hard Drive: 40 GB free space
Graphics: NVIDIA® GeForce® GTX 560 / AMD Radeon™ HD 6870 (1GB VRAM)
DirectX®: Version 11
Sound: DirectX® compatible
Additional Notes: Laptop versions of graphics cards may work but are NOT officially supported.
Windows-compatible keyboard, mouse, optional controller (Xbox 360 Controller for Windows recommended)
RECOMMENDED:
Processor: Intel® Core™ i5-4670K @3.4 GHz / AMD FX-8350 @4.0 GHz
Memory: 8 GB RAM DDR3
Saddly your pc is way lower than the requirements, you will need to update your gear
I have also Dying light FPS issue it just running 10 to 18 fps i think but it is good btw and it only lags when the game is loading the world so here is my specs
OS: Windows 7 Ultimate 64 bit
CPU:Intel Pentium G2020 2.9Ghz
GPU:Nvidia Geforce 630 GT 2gb ddr3 (overclocked)
Ram: 4gb is the minimum of the spec
