First of all i wnat to ask whuch temperature should i watch from HWInfo64
Cpu0
Cpu0 package
Motherboard
Cpu
Cpu
Cpu ( fan speed i guess)
Which temperature is actuall core temperature. And overdrive shows my cpu margin is 48°C on ideal what does that mean?
And now to the point
My config:
CPU : FX6300 with TX3 EVO @ 4.0GHz
GPU : Sapphire R9 270x dual x oc with boost BF4 edition @1100MHz
MB : GA-78lmt-s2 rev1.2
RAM : Simtronics 4GB @ 1600Mhz will buy another stick soon
PSU : Cirsair AX550
Cpu usage while playing dying light is
Core0: 60-90%
All other : 40-51% only
GPU : 60-95%
PS : 35-60
Is it normal?
my cpu0 and cpu0 package temperature is 51 max
And CPU temperature (underis ITxxxx something sensor) 58 max if it is 58 then i need to worry.
also my sttings in game texture: medium, res: 1366×768, everthying on except VSync, view distance: 40%, and other: high!
Cpu0
Cpu0 package
Motherboard
Cpu
Cpu
My config:
PSU : Cirsair AX550
Core0: 60-90%
GPU : 60-95%
PS : 35-60
Is it normal?
