Dying light: The following Enhanced Edition pc resolution! HELP ASAP.
gigabyte2020
115
Hey guys,
I just got dying light: the following enhanced edition on my pc, and am suffering form a problem actually which is making me mad: I have BenQ G900-W 19 inch LCD display monitor which supports up to resolution 1600x900 @75-Hertz but when i open the game itself, i have black screen with a notification bar coming from the screen itself saying out of range! so i tried to change the game resolution to lower resolutions since there isn't an option to set ur refresh rate, THE THING IS WHEN I CHANGE TO LOWER RESOLUTION AND CLICK APPLY IT ALSO SAYS OUT OF RANGE!, but how? my monitor already supports up to 1600x900 resolution, then how all the lower resolutions gives me same out of range? Anyone can help me? also anyone knows how to change game resolution without opening the game itself? another way differ. from geforce experience bec. when i also tried it from geforce experience it also says out of range. I played all other high-end games with same monitor and graphics card (Gigabyte gtx 750 ti 2gb DDR WINDFORCE) on 1600x900 @75 hertz without out of range problem, any help please?
Thanks <3
so, I kept searching and turned out all the resolutions in game are set with very high refresh rates which some of them can't be supported by my monitor and the problem is, u can't set the refresh rate of ur monitor in the game, anyone knows how to change it even from game configfile? or sth. like that? I just want to play dying light and dying light the following enhanced edition.
i managed to find it as i said in first reply, but it only allows me to change the resolution but not the refresh rate of the monitor and the problem is all resolutions in this game are set to maxed refresh rates which some of them aren't supported by my monitor.
