G
Guest
Guest
Hello all. I have the haf922 case right now and I just ordered 2 scythe ultrakaze 120mm fans in which I hear is notorius for noise. I was wondering if I should use some dynamat on my computer case to reduce some noise? I have about 50 square feet left over so I figured I might as well use it on something lol. I do realize that the fan produces mainly wind resistance noise that is not associated with rattling too often, so would it be worth my time to sound proof the case? I was thinking it could reduce other potenial noises. I would also like to know if doing so will affect the internal temperature of the case, and if so, then by how much? Thanks all
