dynamic disk problem
Black_AnGeL
20
how do i restore my basic disk configuration on my dynamic disk? when i right click on my "disk managemnet" and select restore basic disk configuration, it ask me to insert previously save configuration floppy, but i don't have?
I also boot in recovery console and try to fromat it, but can't success🙁
please help me and give me an idea to solve this problem.
THANKS
*ps: i only have 1 hdd and 1 partition in my PC and this is the boot partition and system partition as well.
😎 now i know how to use markup in my post..
Something for everybody to read:
<A HREF="http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnwinpro01/html/winpro0900.asp" target="_new">Choosing the Right Disk Storage for Your W2K System</A>
<A HREF="http://www.labmice.net/Windows2000/diskmgmt/dynamic_disk.htm" target="_new">Dynamic Disks in Windows 2000</A>
And this one for Black_AnGel in particular:
<A HREF="http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q217226&" target="_new">Cannot Revert Boot Drive from Dynamic Disk to Basic Disk</A>
You can't convert a dynamic disk back to basic unless you remove all the volumes, first, which means losing all your data unless you do a full system backup.
Toejam31
<font color=red>First Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=17935" target="_new"><font color=green>Toejam31's Devastating Dalek Destroyer</font color=green></A>
<font color=red>Second Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=15942" target="_new"><font color=green>Toey's Dynamite DDR Duron</font color=green></A>
__________________________________________________________
<font color=purple>"Some push the envelope. Some just lick it. And some can't find the flap."</font color=purple>
cool. I always saw that under disk admin, but never bothered to check it out. Kind of reminds me of the fancy Unix file systems HPUX and Digital Unix has to offer. Thank Toe.
<i>It's always the one thing you never suspected.</i>
yeah, i have follow the step 1-3, but i can't even delete or create partition in following step, so i force to use another win2k to format this hdd and reinstall os and put all my backup in.
damn m$ dynamic disk
