e-GeForce FX5950 Ultra 256MB- Is it dual monitor-capable?
dennis
267
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Does anyone know if the above video card can support dual monitors in
Windows XP Pro?
Right now I am using it via the DVI connection with a Dell model 2001
LCD monitor. I would also like to use a Mitsubishi Diamondtron CRT
monitor at the same time.
Will it work? Or, will I have to use a separate video card?
G
Guest
Guest
It will work. That is my exact setup.
"Dennis" <dyep@cas.org> wrote in message
news:b9aca50b.0405191750.ef6743c@posting.google.com...
> Windows XP Pro?
augustus
740
> Windows XP Pro?
It's dual monitor capable.
http://www.evga.com/products/moreinfo.asp?Part_Number=256-A8-N338-AX&tab=feat
