E machine ET1331G-03W Power supply
crippy
I am looking for a power supply it has an FSP 300-60EP Bronze 80plus 300 watt in it now. I am looking to upgrade, can you help and if so how much will it cost.
Depends on your country. I recommend either antec, enermax, seasonic, or corsair. You can still get a dud, but these brands have more recommendations on hardware sites when tested under load. Google for a power program that gives you the wattage load based on your specs; haven't used one in awhile. This website may have it.
Why are you upgrading the power supply unit? Is it failing or providing insufficient power?
If you are purchasing a new discrete graphics card for this system please post its make and model. We need to know this to be able to provide the correct recommendation.
If you're not upgrading the graphics card please provide a list of the components currently installed in the chassis.
lenharvey
Can I put a geforce 9800 on this machine ( emachines ET1331G ) Also will I have to change the power supply box
The machine has a PCI - Express port
Thanks
lenharvey
Many Thanks for your help !
Similar threads
