Hey Guys,
Just setup my new system yesterday. I had a bit of a hard time getting the stock Heatsink and fan installed(really hate this design) But it seems to be solid now.
At stock speeds I was idling in windows at about 40-45 degrees and mid 60's under full load in prime 95. This is using coretemp.
I've bumped up the clock to 2.7 and now I'm sitting at about 50degrees Idle and low-mid 70's under full load.
This is with the voltage set to auto because so far I've been having trouble getting the system to post when I manually set it. Computer is very stable right now though.
So, do you think the Heatsink still isn't seated properly?, the voltage is screwing me or is it something else?
To be honest I'm leaning towards heatsink and fan not being seated well, just because it was warm even at stock. Of course I've screwed around with the HS so much now that I'm getting worried about screwing up the stupid plungers.
Should also note I'm using the Sonata III with a 1200rpm intake fan and the exhaust fan on the middle setting.
