E35M1-M users, please help
johnsmith1261
Hi!
Is the E35M1-M or E35M1-M Pro capable of 1920x1200 resolution via DVI? Their specifications say that these boards support 1920x1080 at max, but it's confusing, as the E35M1-I Deluxe supports 1920x1200 thru DVI.
Is it at an error in the specifications or the E35M1-M/E35M1-M Pro can send 1920x1200 over DVI? Could someone who owns these boards check it for me please? :)
Thanks,
j
Windows 7 will detect the highest resolution your monitor can run at. Use the "detect" option if your resolution is not the highest your monitor can handle. According to Asus specs, the highest resolution your onboard video can handle is 1920 x 1080 http://www.asus.com/Motherboards/AMD_CPU_on_Board/E35M1M/#specifications. If you're not able to run your monitor at this setting, check the device manager in the control panel for your display adapter. You can highlight this device driver and let windows search for an updated driver, or go to amd's website and install their latest driver.
Sorry, I forgot to make it clear that I'm before buying one of these boards, that's why I asked if a real owner could reply 😉
