ok so ive had the board because previously i had a PD805 @ 3.8 GHZ but i know C2D is better, so when the 4300 dropped i was excited cause it had a higher multi than e6300 and this board i have hits a wall on the FSB so i wanted the higher multi to accomodate this board better however i ran into a problem.
so i went and bought one from frys' however im having a problem. when i put that chipp in and i have my latest bios revision mind you(603). i cannot change the FSB in the tuning options in the bios, instead its stuck at 2745 and whenever i make a attempt to change it, it just pops back to 2745. so i thought this board is only capable of 1600 atleast as advertised. so i let it boot. well when i let it boot like this, i expected it not to but it did but it did not boot with this crazy high FSB it booted the proc at 1.56GHZ and the FSB at around 693 or 173 external clock. so wtf is wrong? i called asus they want nothing to do with it. i just want to know. did i buy a bad proc? because it works fine on auto at 1.8GHZ 800 FSB or has anyone else tried this board and processor. also i know this board isnt great and its Nforce4
Asus P5N32 SLI SE Deluxe
C2D E4300 @ 1.8 ghz
Zalman CNP 9500
Corsair TWIN2X2048-6400c4
EVGA 8800GTX
Thermaltake toughpower 650W
Antec 900 case
bottom line has anyone else with this same MB try this CPU? or did i just buy a bad proc?
C2D E4300 @ 1.8 ghz
Zalman CNP 9500
EVGA 8800GTX
Antec 900 case
