EDIT: added CPU-Z screenshot: http://www.ryu.at/clip2.jpg
hi,
stable config:
E4300 (dont know stepping, bought it end of april)
Scythe Ninja Plus (with 120mm fan)
Gigabyte P965 DS3 rev3.3
Corsair XMS2 PC5400 CL4 (see link below)
be quiet PSU 450W
CPU temp = 25 degree celsius (idle)
CPU temp = 44 degree celsius (load)
mainboard temp = 35 degree celsius
several fans installed. pretty drafty inside the case.
FSB = 320Mhz
CPU clock = 2880 Mhz
memory divider = 1:1
memory clock = 640 Mhz
latencies = 4-4-4-12
Vcore = 1.296 (idle)
Vcore = 1.280 (load)
vDIMM = 1.9V
all other voltages at default values
now for my problem:
I tried a lot of settings for memory (voltages up to 2.0 - don't wanna go higher; and various latencies, cl4 and cl5), but I cannot exceed an FSB of 320. Starting windows at 333Mhz CL4 1.9V is possible, but black screen when antivirus and firewall programs are loading...
This means that my memory runs only at 640Mhz at 1.9V and 4-4-4-12 (increasing to 2.0V and 5-6-6-18 doesnt help).
I've now checked what exact memory I have. Specs are here:
http://www.corsairmemory.com/corsair/products/specs/TWIN2X2048-5400C4.pdf
According to this pdf, my memory should run at 667Mhz with 4-4-4-12 with no problem. hell, it should even go up to 675Mhz!
Does that have anything to do with the memory divider? it is 1:1 of course, not the default of 5:3. If not, what's wrong with that memory?? 🙁
does anyone know what means "Option1" and "Option2" for the memory configuration on the Gigabyte 965P DS3 rev.3.3 mainboard? I have it at Option1 (default).
help plz 🙁
hi,
stable config:
be quiet PSU 450W
FSB = 320Mhz
vDIMM = 1.9V
now for my problem:
help plz 🙁
