my specs:
e4500 core 2 duo 2.2 ghz
Asus P5K-vm (g33) motherboard
corsair xms2 800 mhz 2 x 1024 mb
xfx 8600gt 1 GB ddr2
350 watt supply
stock cooling
now i want to overclock my cpu on stock cooling. i went to the bios and changed the fsb to 245 so the processor went to 2.7 ghz with normal temperature at aroud 48 degrees. the system was completely stable according to prime95. i ran the tests for 45 mins. then i changed the fsb to 265 so processor was at 2.9 but the system failed to load up. the voltages were at auto.
i want to reach atleast 3.2 on stock cooling. is there a safe way to do that changing the voltages? And another question, what is the max. temp at which the cpu will be safe? please give me a friendly suggestion because i do not want to waste my processor.
350 watt supply
stock cooling
