So I am having an unusual issue while trying to install a new CPU. I replaced a i7 3930K with a E5 1680 V2. While doing my benchmark suite I noticed some weird points of instability at stock that get exaggerated when an OC is attempted. To put it simply if I leave turbo frequencies enabled at stock settings the system will crash in a couple of unique situations. If I turn off my TV (ie my PC is connected to an Onkyo receiver then to a 4K TV) and turn it back on again it appears to crash the video card (currently not overclocked either) if and only if my CPU is under load while turboing higher then 3.1ghz. if there is no load or it in only at 3.1ghz or less the TV turns on fine and I still get a video feed. So as you can imagine any over clock above 3.1 ghz causes the same issue even though the OC is stable with multiple benchmarks/stress tests (save one, sandra). Now I can switch between inputs and all that and still have a video signal at any turbo frequency and CPU load. It is only when turning the TV off I crash completely.
Now for the other oddball. Sandra sisoft benchmark suite crashes the CPU regardless of settings. Stock or otherwise. At stock I can get it to "sometimes" pass but not all the time. Yet intel burn test on maximum for 5 hours is rock stable, same for prime 95 (8 hours), aida64(5 hours), furturemark, memtest86...to name a few whether I am at stock or up to 4.3ghz (haven't found a stable 4.4ghz setting yet).
So my point is what am I missing? Do I just have a bad CPU or is there a setting I am missing? listed below is my overclock settings...stock settings mentioned above are well stock. Both OC's listed have been done with and without ram OC if Ram is OC'd it is DDR3 2400 cl10 T1 with 1.65 volts at "stock" it is running DDR3 1333 CL 9 T2 1.5 volts. OC temps are ≤ 62C
sync all cores
core ratio 43
Vcore 1.21
VTT 1.15 (went as high as 1.18125)
VCCSA 1.050
CPU spread spectrum disabled
PCIe spread spectrum disabled
C states disabled
Speedstep disabled
LLC ultra high
CPU current capability 180%
VCCSA LLC High
VCCSA Current Capablilty 130%
Dram Current Capability 140%
Basically I followed this guide aiming for a 4.4 ghz...
vloggest.com
I also did my "own" semi stable OC and it looks more like this
sync all cores
core ratio 43
Vcore 1.21
VTT auto
VCCSA auto
C states disabled
Speedstep disabled
LLC ultra high
VCCSA LLC High
Am I missing something or do I have a bum CPU??
sync all cores
core ratio 43
Vcore 1.21
VCCSA 1.050
C states disabled
Speedstep disabled
LLC ultra high
VCCSA LLC High
X79 Overclocking Tutorial - i7-3930K? No problems? 1680 v2? Easy! - Vloggest
Here is the overclocking tutorial for X79, which oddly enough you guys were r...
sync all cores
core ratio 43
Vcore 1.21
VTT auto
VCCSA auto
C states disabled
Speedstep disabled
LLC ultra high
VCCSA LLC High
