E5200 Water cooling
da boi
38
Hey,
I was just wondering what Kind of Speeds I should be able to get with a H50 on my e5200?
I was kind of hoping to get 4.5GHz but maybe that's a bit ambitious.
Any ideas on temps and voltages?
Thanks in advance.
Didn't you already make a thread with exactly the same question? Keep it to one.
PS: 4.5 GHz isn't going to happen unless you move to a cooling solution far more advanced than an H50.
Just stop don't spend money on overclocking that get at least a q8200 if going water I have a q9400 at 3.8 with air just no need for water and no need for more than 4ghz you just won't notice anything above that.
T
1. 4Ghz+ OC on the E5xxx and other Pentium Dual Core CPUs are hard with out high end WCing and high voltages.
2. The H50 is no better than a pretty good air cooler such as a Core Contact Freezer (~$20 right now at Newegg after MIR).
3. Full specs?
@Thently: I'd like to see you try 3.8Ghz with out WCing on a i7 + Turbo.
False. It depends on the PROGRAMS you are running. Programs such as MAYA,etc you WILL notice a difference.
index.php
corsair h50 , 26'C in my room
