Ok, so I'm following graysky's guide and I've run into an error problem during the process. In my system I'm running:
-2.13ghz e6400
-Gigabyte 965p-ds3 mobo
-2x1gb corsair cm2x1024-6400
-antec truepower 2 550w psu
-seagate 500gig 32meg cache hdd
-nvidia 7600gt vid card
Where I ran into the problem is the step where I start raising the bus speed of the cpu, (I'm using a multiplier of 8 and the default is 266) I raised it to 276 at 1.250 vcore and ran Prime95 for an hour with no errors. I raised it to 278 and started running into all kinds of errors in windows, so then I ran memtest and got about 52 errors just 44% in. I reset the bus speed to 266, vcore to 1.325, and the DRAM multiplier back to 3 from 2 (synchronous) and everything's working fine with no errors in memtest. Now I'm wondering where this problem manifested, is it just because my vcore was too low or was it because when I lowered the DRAM frequency multiplier to 2 my ram timings dropped from 5-5-5-18 to 4-4-4-12 (which is below spec on my ram)? If that's the case do I just leave the multiplier at 3 and let the DRAM frequency climb or will that cause problems by the DRAM frequency going over 800? I can't imagine the bus speed is too high since the average people seem to overclock this chip to is 3.2ghz, so I doubt I'm getting errors because of that.
Another question I have now is for some reason now when I start my computer, before post and before anything really turns on there's a loud ~3 second beep, I can't figure out why. Any ideas on why this beeping would be happening? I'm not going over any temperature thresholds or anything and all the fans are working.
-2.13ghz e6400
