What temps should I be at on an idle 6600, at stock 2.4 with a Zalman 7000 installed. I didn't do this build, Mwave did, the system runs fines, but I get this on and off beep. ( I assume the 8800 gts doesn't beep) after a bit, it's a steady constant beep.
I assume the most accurate temp readings come from the Bios, is this right?
I am really not 100% whats wrong, but it seems to stop beeping after I take the side window off. It's an Apevia Cruiser, with 3 90mm fans.
