E8400 stock
Scythe Mine REV.B Heatpipe CPU Heatsink http://ncix.com/products/index.php?sku=20690&promoid=0
Gigabyte 3D Aurora Black Aluminum ATX http://www.ncix.com/products/index.php?mode=productreviewread&product_id=17051
Evga nForce 780i MB
OCZ Reaper 4GB DDR2
Evga 9800gtx
So recently my video card died. So i decided to overclock my CPU to 3.6Ghz because i only had 1 card left. When i did get everything running i noticed that the CPU temp were really high on idle 57C and 75C under load i had to stop because it just kept getting hotter. I Reset everything to default to see if it was the overclock that was causing the high temp. On everything stock, idle is at 52c and under load it's at 67C . i haven't checked my CPU temp since i build my PC over a year ago and it was around 42C on idle and 57C under load. Anyone know what could be causing the high temp or a way to get the CUP temp down? I read somewhere that if don't have the latest BIOS it could cause the high temp. Is this true?
Evga nForce 780i MB
OCZ Reaper 4GB DDR2
Evga 9800gtx
it jumps from 3000MHz to 2999.9 to 2000.1 to 1999.9 then back to 2999.9 all randomly.i don't know what the hell is going on. I've check the BIOS and it's set to 3000. Could this be a dying CPU?
