Alright so my new build is in the works. I am very confident of my choice of hardware even though some components may not be cost/performance effective. I assure you there are a lot of features and stability issues that I have tried to address. Although my biggest concern is weather everything will actually fit in my case and if there is enough ventilation to keep "my precious" (yea bad lord of the rings joke) cool. Most of my cases in the past have been cheap and I finally decided to splurge and get something decent but the case I want is only a mid tower and I don't see an awful lot of fans. I am willing to part with this decision but to be honest I think most cases even pricey ones look pretty tacky. Again my biggest concert is with the size of the motherboard It is an extended ATX motherboard which I would hope it has the same layout for mounting holes as a standard ATX board. Then I have a Corsair AX1200 PSU which might also be a problem as its pretty hefty and many people say EATX is a little bit longer maybe a centimeter. Pretty sure the PCI-E slots will alight correctly in the case hopefully there is enough room for both cards and my PCI express sound card however I would be willing to part with that. If you can think of any cabling issues or really anything else for that matter I would really appreciate anyone's input.
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131760
PSU: http://www.amazon.com/Corsair-Professional-1200-Watt-Certified-High-Performance/dp/tech-data/B003PJ6QVU/ref=de_a_smtd?ie=UTF8&m=A35DL6C7BAXYRR
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139005
Graphics card: GTX 580 SLI
