[SOLVED] ECS G41T MotherBoard 2 Different RAM speed Problem
Jun 23, 2022
7
Can ECS G41T-M6 V3.0 MotherBoard Work with 2 DDR3 8500U & 12800U 2GB RAM modules ? How will 2 different speed RAM modules Affect this Board ? Will Board Atleast Power on ?
Probably, it's 2 different kits, so no guarantees or certainty.
How will 2 different speed RAM modules Affect this Board?
It won't affect the board at all. But will happen, assuming it works, is that you'll be running the slowest of the 2 speeds, with the worst (if not worse) timings and voltages. The ram affects the memory controller and vice versa, nothing to do with the board as such.
Hold on, I know I have a reliable Crystal Ball around here somewhere, I'll consult it and get back to you....
Karadjgne
Ambassador
