Edge to Edge monitor
dustypp1
15
I want dual monitors, I hate the screen gap that the monitor frame creates. What are good gaming monitors (5ms or less) that are edge to edge?
You may be better off buying an ultrawide (34"+), to be honest. It's not a cheap investment by any means but will definitely resolve the screen gap you'd have of pushing two smaller monitors together. Plus, given the space, you can view productivity stuff side-by-side should that be a need. There's no shortage of ultras out there, so find one you like and start saving for it. I'm hoping you've got a good GPU to power it as you'll need it.
