[SOLVED] EdgeRouter X not outputting wifi
nhardinger2003
230
14
10,595
So ive got an edge router X for a router bridged with my providers one. It has been working great for a few months, I have old routers converted into access points to get wifi to the other parts of my hosue. My issue is that I currently no longer can connect to any of the ports on the router to get wifi except the config port (eth0 to be exact). Its really annoying considering ive reset the configeration, ive tried restarting multiple times, and im on version 1.10.10(2.0.7 is buggy for me). I really need to get the wifi back up in my house soon beacuse ive got things that are needed on it tomarrow. Please if you have any ideas to help that would be great.
check that dhcp is up. you can configure ip,gw, and dns on a device to check if it's routing.
have you tried resetting it and going through the wizard again? in the docs it looks like you must manually setup your ip to access it the first time. it defaults to 192.168.1.1/24 so make yours .1.2
default user and pw both ubnt
