Question Eero Mesh WiFi system ?
stephent181
7
Hey folks - girlfriend and I are staying with her parents while we save for a house...and they have the
Eero Mesh WiFi system. There are 2 total Eero hubs. The main hub is in the living room, the wireless one is the one I am using. We have 2 GB speed at the house, but I'm only getting 400-600 MB from an ethernet into the hub in here.
Am I able to connect an ethernet cord from the main hub to this wireless hub so I can gain access to the full speeds? Or would this not work.
My apologies if I explained that terribly.
Not sure you would get the 2gb all depends on if the devices and your pc have 2.5g ethernet ports.
You should be able to get 1gbit. Cabling the main router to the remote unit is always the best option if you can get the cable run. The remote unit will act as a simple switch.....I assume it has at least 2 ethernet ports.
I am somewhat surprised you get such a high speed using wifi between the remote and main router.
Reactions: stephent181
Maybe a better questions is why. Only large file downloads need lots of bandwidth. How much do you download per day. Other applications only use what they need. Netflix for example will only use 30mbps watch 4k having more will not make it run faster or better.
The kinda a exception is if you play online games. Games only need about 1mbps but they do not tolerate the random latency spikes wifi has. In these cases you want ethernet more for the stability than the added bandwidth.
We have 5 people using the internet in the house - before the speed was upgraded there were random lag spikes while I was playing NHL on Xbox. Obviously in the middle of a fast-paced hockey game that isn't great.
I haven't noticed any yet, but I guess I do not need to make any further adjustments if we have enough speed to prevent any issues on my end?
https://support.eero.com/hc/en-us/a...d-is-eero-capable-of-What-about-its-bandwidth
There are so many eero models, which one do you have? And don't quite understand your description.
So you connect two eero hubs using wifi, but your pc plugs into the ethernet port of the hub that's in your room?
if that's the case, 600Mbps can be considered good. 4K video requires 30Mbps only as mentioned above.
Wired ethernet of course is way better then wifi in stability, however.
Sorry, we have the Pro 6E. The speed tests I run on various sites fluctuates from 400-600, 600 being the max and only on one of the sites. I know some are better than others so I tried to run a few. Played hockey last night and did not have any problems. My ping is still fairly high for the games, no change from before, but I assume that has mostly to do with the locations of the other players I'm with.
Appreciate it! So far it has been okay. If I have any issues I'll explore the direct connection to the main Eero. Thanks folks!
Eero now says you can. Didn't used to be this way, until they came out with their POE model in 2022 but now all of their firmware allows it. Keep in mind that as mentioned you would be limited to gigabit speeds at the end of the line, but constant 900mbit is better than sometimes up to 600, plus you aren't polluting the air with excess backhaul traffic so your wifi devices may be faster too.
This works if you have only one ethernet device (your PC) plugged into the satellite node, since with only two wired ports on each node, all of the other ports would be filled. If you wanted more wired devices at either location, you could add an inexpensive network switch.
